Ellex - SLT Solo
by Ellex
The Ellex Solo is a solid-state ophthalmic laser system designed specifically for selective laser trabeculoplasty (SLT), which is an advanced, non-invasive surgical approach for stimulating the generation of healthy trabecular meshwork cells and managing intraocular pressure. This repeatable treatment promotes cellular regeneration without the burn and scar tissue associated with other laser procedures.
2RepliesSat May 02 2026 | manuel where can i find the manuel Equipment: Ellex - SLT Solo Reply |
0RepliesMon Apr 20 2015 | erreur E61-S (SLT SHUTTER OPENED WITHOUT REQUEST ERREUR) J’ai un laser Marque : LASEREX SOLO Réf: LT5106-S SN:SLO129 Pour traitement du glaucome qui nous indique après l'allumage nous indique erreur E61-S (SLT SHUTTER OPENED WITHOUT REQUEST ERREUR) Si vous plais aider moi a résoudre le problème Cordialement. Reply |
0RepliesSat Apr 11 2015 | system error code E61-S LASER (Ellex SLT Solo ) message erreur: -SLT SHUTTER OPENEQ WI THOUT REQUEST ERROR Reply |
[list] [*] Built-In, Fully Integrated Design - Ellex’s fully integrated design optimizes laser treatment and provides a number of advantages, including a shorter travel distance for the laser beam, no add-ons or cables, and more stable, reliable and consistent delivery of energy. The Solo’s built-in slit lamp features converging optics to provide a more natural stereoscopic view that is ideal for anterior segment viewing. This compact, efficient design creates more working space for the physician, as well as convenient, simultaneous access to the patient and laser controls. [*] SLT Photoregeneration - SLT is a highly effective approach for first-line glaucoma treatments, adjunct therapy with drugs, and alternative therapy when drugs or surgery fail. It is also a flexible treatment option, because it can be repeated, if necessary, depending on the individual patient’s response. SLT uses short pulses of lowenergy light to target the melanin in specific cells of the affected eye. In response, the body’s natural healing mechanisms rebuild these cells, improving drainage and lowering intraocular pressure. The surrounding, non-pigmented cells – as well as the rest of the eye structure – are untouched and undamaged [*] Ellex SLT Technology - The Ellex Solo features a high level of precision, in which parameter settings can be adjusted at 0.1 mJ increments. This capability, coupled with superior energy control and the fastest repetition rate in the industry at 3 hertz, enables the physician to deliver quick and highly accurate SLT treatment. All SLT treatment parameters are designed to industry-recognized treatment protocols, maximizing treatment options and ensuring effective patient results by enabling the physician to tailor treatment to the individual patient’s response. [/list]
| Laser Type | Nd:Yag |
| Height | 53 in |
| Length | 20 in |
| Weight | 99 lbs |
| Wavelength | 532 nm |
| Width | 36 in |
Energy: 0.3 to 2.6 mJ, single pulse, continuously variable Pulse Duration: 3 ns Electrical Requirements: 100 - 240 VAC, 50/60 Hz, 500 VA
