ConMed Linvatec - 10K
by ConMed Linvatec
Ease of use and superior performance are the key characteristics that make the 10k® Fluid System unique. The 10k Fluid System, when used for Arthroscopy, maintains intra-articular pressure, while providing instantaneous flow and overpressure control. The 10k Fluid System, when used for Laparoscopy, provides instantaneous fluid flow or suction in the abdominal cavity.
0Repliesa year ago | Conmed 10k - Error code E07 when pressing run troubleshooting portion of the user manual is a waste of ink. Any idea what the code refers to? does the cartridge have a magnet or iron based strip in it? |
2Replies3 years ago | Error code E 30 What does this error code meanReply |
2Replies4 years ago | Marcos - Biotec Cnv Friends, i need the technical manual of the linvatec 10k pump, for preventive and corrective maintenance Reply |
[list] [*] Intuitive one-step/one-hand cassette loading [*] Quick setup and priming [*] Integrated pole mount works with any standard I.V. pole [*] Compatible with video cart shelf or any flat surface [*] Immediate response [*] High flow [*] Maintains distention even under demanding situations [*] Robust autoclavable remote control [/list]
Height | 6.5 in |
Length | 8 in |
Weight | 7 lbs |
Width | 7.75 in |
Voltage: 90-240v Cable Length: 10 ft. (3m)
