Stryker - MultiGen
Lension Generator
The Stryker MultiGen™ radiofrequency generator handles up to 4 lesions simultaneously with independent control. With multiple options for customizing procedures, MultiGen also features software safety checks and monopolar nitinol electrodes.
0Replies2 years ago | Error message Can someone help? Stryker Multigen RF generator display error message 0xc004 during start up. ThxReply |
2Replies6 years ago | Guide for Cleaning and Disinfection Anyone can give me the instruction on how to clean and disinfect of the probe?Reply |
- Multi-Lesioning:Handles up to 4 lesions simultaneously and with independent control
- Offers a multiple start option as well as an individual start option to deliver RF energy
- Performs monopolar and bipolar procedures at the same time
- Reduces overall procedure time
- Parallel Bipolar: Allows 2 parallel bipolar procedures to be performed simultaneously
- Features an option to perform thermal and pulsed procedures at the same time
- Intradiscal Lesioning (IDL): Offers pre-programmed time and temperature step profiles
- Allows time and temperature adjustments on the fly
- 12.5 in. [317.5mm] width
- 8 in. [203.2mm] height
- 15 in. [381mm] depth
- 100–120 –V 50–60 Hz
- 230 V–50 HzA
- 50-watt maximum power into 100–ohm resistive load
- Display screen -5.5 in. x 8 in. LCD, wide 160° minimum viewing angle
- Conventional heat lesion: 1 MHz, accuracy ± 10%, DualWaveTM
- Waveform: aperiodic damped sinusoid
- Pulse mode: 1 MHz sine wave with selected pulse frequency and on time, accuracy ± 10%
