Monitor Instruments - MI-5000B
by Monitor Instruments
The MI-5000B Series II Microprocessor Audiometer
It administers computerized tests securing valid, reliable data quickly and cost effectively. It is very easy to understand and use, and can be used either alone, or interfaced with an external printer or computer. Interface settings can be changed by the operator. Tones are generated and controlled entirely by digital circuits, allowing output levels of the MI-5000B to be adjusted by through secured keyboard entry. The LCD display simultaneously shows all thresholds established for both ears, as well as on-going test conditions.
FORUMSView All (6)
-Measley
Thu May 28 2026
Manual
Can you provide a manual?
Equipment: MI-5000B
-TerryM
Sun Jun 02 2024
Where to get Audiometer repairs in Canada?
-Roland Faulkner
Mon Apr 17 2023
what port number
we had to setup MI5000b on another computer what port sit communicating over... port 1 2  or 3 or what is the specific port number?
[list]      [*] Built in talk over with automatic pause while in use      [*] 2 in 1 serial port configuration (pin-out compatible with older versions)      [*] Excellent immunity to low line voltages      [*] Rugged construction      [*] Allows for field calibration of output levels      [*] Three frequency threshold averaging on printouts      [*] Capability for switching from automatic to manual as needed      [*] Option to start either ear, and whether to test 8 kHz.      [*] Starting ear, whether to test 8 kHz and other audiometer parameters can be stored in non-volatile memory      [*] 'Listening' test controlled by the patient response switch from inside the booth      [*] Optional automatic shut off after one hour when not in use (selection stored in non-volatile memory)      [*] Elapsed test time printed on test results      [*] Flags on printout show which thresholds were determined manually      [*] Audible alert for end of test and error conditions (toggled active or inactive from front panel)      [/list]
Height2.75 in
Length 9 in
Weight2.6 lbs
Width7.5 in
Test Frequencies: 500, 1000, 2000, 3000, 4000, and 6000 Hz. 8000 Hz is optional      Frequency Accuracy: Crystal controlled, less than 1% error at all frequencies      Intensity Range: From 0 dB to 90 dB Hearing Level (HL) in 5 dB steps      Testing Time: On a cooperative individual or a biological simulator, approximately 5 ½ minutes (testing 8 kHz.)      Power Requirements: 120 VAC, 60 Hz, 32 VA
