Biodex - Balance System SD
by Biodex
The Balance System SD will improve balance, increase agility and develop muscle tone
The Biodex Balance System SD has been designed to meet the needs of everyone looking to improve balance, increase agility, develop muscle tone and treat a wide variety of pathologies. Featuring easy-to-follow “touch-screen” operation, the Balance System SD is simple to learn and operate, leading the user step-by-step through testing protocols and training modes in both static and dynamic formats. Extremely versatile, it is the only system that provides a fast, accurate Fall Risk Screening and Conditioning Program for older adults; closed-chain, weight-bearing assessment and training for lower extremity patients; and adds the objective balance assessment component to a concussion management program.                    The Balance System SD also serves as a valuable training device to enhance kinesthetic abilities that may provide some degree of compensation for impaired proprioceptive reflex mechanisms following injury. Using this unique device, clinicians can assess neuromuscular control by quantifying the ability to maintain dynamic bilateral and unilateral postural stability on a static or unstable surface.
-dsettergren_1657
a year ago
Need a touch screen or any display for the Biodex - Balance System SD 950-300 or any other.
We need a whole touch screen panel or the display board behind it for the Biodex - Balance System SD 950-300 or any other. These are no longer available from the manufacture. Or we'll have a nice looking system to part out...
-Tiger
8 years ago
Calibration
I need help calibrating a 945-300 machine. When it tells me to press down on the platform at the3,6,9and 12 o'clock position how far do you depress? Thanks for any help.Reply
[list]          [*] Static and Dynamic (SD)          [*] Balance Training          [*] Enhanced Sensory Integration Balance Testing Capabilities          [*] Custom Reporting          [*] Six Training Modes and Five Testing Protocols          [*] Standardized Fall Screening and Athlete Knee Injury Screening Tests          [*] Normative Data          [*] Audio Biofeedback          [*] Visual Biofeedback          [*] Multipurpose Connectivity          [*] Adjustable Support Handles          [*] Locking Surface          [/list]
Height74 in
Length 44 in
Weight196 lbs
Width30 in
Platform Dimensions: 21.5" diameter  Monitor Dimensions: 9.75" w x 7.25" h  Monitor Viewing Area: 12.1"  User Capacity: 400 lb          Power: 115 VAC, 50/60 Hz, 15 amp line or 230 VAC, 50/60 Hz, 15 amp line
