Nihon Kohden - Cardiolife TEC-8300
by Nihon Kohden
Defibrillator
Nihon Kohden's compact portable Cardiolife TEC-8300 defibrillators are ideal for emergency use. Charging and recovery are quick. These devices support AED (automatic external defibrillator) mode, and are equipped with a high-resolution TFT colour display. SpO2 and CO2 measurement is supported. Cardiolife TEC-8300 defibrillators enable defibrillation using a low-energy biphasic impulse curve. Defibrillation with a biphasic impulse curve takes less energy than the usual monophasic defibrillation, causing less damage to the cardiac muscle. Biphasic technology gives you better results in keeping patients from sudden cardiac arrest. This unit supports AED (automatic extended defibrillation) using an adapter cable for optional disposable shock pads. As soon as the unit detects a defibrillated rhythm, the TEC-8300 will start to charge for hands-free defibrillation. A signal tone will sound to optimise resuscitation activity timing.
-salameh
8 years ago
battery calibration
nihon kohden bettery calibrationReply
4
-biomed683
8 years ago
Nihon Kohden TEC-8321 Defibrillator Battery calibration fault
Hello everyone
i need your help regarding the battery calibration problem on NK Tec-8321 defibrillator
when I enter into setup menu by Turn the control dial to BASIC CHECK-position while pressing the silence Alaram key. where I select the No2 option to get battery calibration menu to press the  OK button . the display return back to basic check screen instead of battery calibration menu further. I tried many times but facing same problem. The battery is only one year old and did not calibrate from the last one year.
your help regarding this will be highly appriciated ..
I don’t know it’s any software problem or something else. Need your help regarding this issue.
SERVICE COMPANIESView All Defibrillator Companies
  • High-resolution 8.4” TFT color LCD display for showing ECG, pulse, energy charge, 12-lead ECG, CO2/SpO2/NIBP/IBP/Temp
  • Up to 6 traces can be shown simultaneously
  • Provides intuitive and user-friendly AED function and external pacing
  • Paddles that include external and internal paddles and disposable pads can be easily changed with one connector
  • 12-lead ECG data can be shared with mobile devices via Bluetooth
  • Data transmission to remote facilities by email
  • Nihon Kohden’s polaris.one data management system allows to view data at the hospital on a PC with ECG viewer software
  • Self-test indicator that facilitates daily and monthly tests
  • AC/battery operation
  • Built-in thermal array recorder records variety of defi brillation information
  • SD card for storage
Height362 mm
Length 262 nm
Weight6.8 kg
Defibrillator TypeExternal, Manual
Width334 mm
  • Display size:8.4 inches
  • Sweep length:136.2 mm
  • Sweep speed:25 mm/s, 50 mm/s
  • Measuring range: 0 to 45°C, 32 to 113°F
