Leica Biosystems - CM1800
by Leica Biosystems
Cryostat
Up-to date microprocessor technology ensures easy operation. All function keys are protected against dirt and humidity by a plastic foil. A locking key prevents inadvertent changes of the programmed set temperature and defrost time. Easily readable display. Automatic display of error conditions. All programmed parameters are protected in event of a mains power failure by a battery-backed memory. The ergonomically positioned handwheel is conveniently accessible. A safety lock prevents inadvertent movements of the specimen head to safeguard user against injuries when changing the specimen or knife. Easy-to-use specimen orientation to produce top quality sections- even of critical samples such as skin- in a minimum of time.
FORUMSView All (10)
-Bobby legecy
Thu Dec 11 2025
COMPRESSOR
I need a refrigeration compressor for the Leica CM1800. Is there an aftermarket one that I can use in this unit?
Thank You
Equipment: LEICA CM1800
-Bobby legecy
Thu Dec 11 2025
COMPRESSOR FOR THE LEICA CM1800
I need a compressor for the Leica CM1800. Is there an aftermarket for this compressor, or a compatible one I can use?
-Ross
Wed May 08 2024
Leica CM1800 cryostat - user is looking for a user manual
One of my histotechs is looking for a user manual for a Leica CM1800 cryostat.
Does anyone have a digital file of the user manual?
[list]    [*] Microprocessor control    [*] Motorized coarse feed    [*] Rapid specimen orientation     [*] Universal knife holder system    [*] Compact dimensions    [/list]
Height1165 mm
Length 670 mm
Weight125 kg
Width695 mm
Section thickness setting: 1 to 60um     Maximum specimen size: 55mm     Horizontal specimen feed: 25mm     Vertical specimen stroke: 59mm     Trimming: via motorized coarse feed     Motorized coarse feed: 2 speeds     Temperature setting range: 0 C to -35 C     Cooling down time to -35 C: 4h     Defrosting: Programmable     Freezing shelf temperature: down to -45 C
