Ellex - Integre
by Ellex
The Ellex Integre is the first and only solidstate green laser that incorporates the laser cavity and slit lamp in an efficient, self-contained design. Because the laser cavity is a fully integrated component of the Integre system, the beam has a shorter distance to travel, delivering more stable, reliable and consistent energy. This integration also minimizes system down time because there are no exposed fiber optic cables to accidentally damage. The Ellex Integre features a unique True Spot™ optical system that delivers a sharpedged, uniform laser spot. The result is consistent and repeatable tissue effect for precise treatment of a number of retinal conditions.
2RepliesTue Jul 09 2024 | Error 1001 request for service manual Need service manual for ellex integre Equipment: Ellex integre Reply |
0RepliesMon Jun 11 2012 | cavity is there a company which sells the cavity of ellex? except ellex company and dealers Reply |
[list] [*] Built-In, Fully Integrated Design - Ellex’s fully integrated design optimizes laser treatment and provides a number of advantages, including a shorter travel distance for the laser beam and more stable, reliable and consistent delivery of energy. The Integre’s compact, efficient design creates more working space for the physician, as well as convenient, simultaneous access to the patient and laser controls. [*] True Spot™ Optics - The True Spot™ optical system offers a uniform, sharp-edged top-hat beam on the retina, providing the benefits of a parfocal system, with the added comfort of low power density at the cornea. [*] Superior Energy Distribution - Ellex lasers are manufactured with the highest quality optics and laser components available in the industry, with real-time energy control that continuously monitors and adjusts power output throughout each exposure. The result is even energy delivery from beginning to end of exposure, across the full diameter of the spot, without creating hot spots. [*] Optimized Retina Slit Lamp - The Integre slit lamp combines a unique 10-degree convergence angle of viewing paths with high-resolution optics to create better depth perception and an improved stereo angle for superior peripheral viewing. [/list]
| Laser Type | Diode |
| Height | 55 in |
| Length | 20 in |
| Weight | 112 lbs |
| Wavelength | 532 nm |
| Width | 36 in |
