Ellex - Integre Duo
by Ellex
The Integre Duo is the first solid-state photocoagulator to deliver clinically proven 670 nm red and 532 nm green wavelengths.
The Integre Duo is the first solid-state photocoagulator to deliver clinically proven 670 nm red and 532 nm green wavelengths. This advanced laser system makes it possible to instantly switch between red and green wavelengths for seamless retina treatments. This not only maximizes treatment options, but ensures effective patient results.         For common procedures like retinal photocoagulation, laser trabeculoplasty and iridotomy, the Integre Duo’s green wavelength provides the standard of care. The red wavelength produces less scatter for better transmission through a cloudy cornea or lens, provides deeper penetration for effective treatment of choroidal vessels, and enables the physician to treat in the presence of a minor hemorrhage.
[list]  [*] Built-In, Fully Integrated Design - Ellex’s fully integrated design optimizes laser treatment and provides a number of advantages, including a shorter travel distance for the laser beam and more stable, reliable and consistent delivery of energy. The Integre Duo’s compact, efficient design creates more working space for the physician, as well as convenient, simultaneous access to the patient and laser controls.  [*] True Spot™ Optics - The True Spot™ optical system offers a uniform, sharp-edged top-hat beam on the retina, providing the benefits of a parfocal system, with the added comfort of low power density at the cornea  [*] Single Pump Dual Cavity Design - The Ellex design team capitalized on 20 years of ophthalmic laser innovation to create a multi-color photocoagulator that incorporates a number of laser industry firsts. These include a unique single pump, dual cavity specifically designed to make photocoagulation procedures as effective as possible. In addition, the laser cavity has been combined with the slit lamp and other system components to ensure efficient delivery of the laser energy and maintain stable alignment.  [*] Superior Energy Distribution  - Ellex lasers are manufactured with the highest quality optics and laser components available in the industry, with real-time energy control that continuously monitors and adjusts power output throughout each exposure. The result is even energy delivery from beginning to end of exposure, across the full diameter of the spot, without creating hot spots.  [*] Optimized Retina Slit Lamp - The Integre Duo slit lamp combines a unique 10-degree convergence angle of viewing paths with high-resolution optics to create better depth perception and an improved stereo angle for superior peripheral viewing.  [/list]
Laser TypeDiode
Height55 in
Length 20 in
Weight112 lbs
Wavelength670 nm green: 532 nm
Width36 in
Exposure Time: 0.01 to 4 seconds     Spot Size: 50 to 1000 microns, continuously variable     Aiming Beam: red diode, adjustable intensity     Magnification: 6x, 10x, 16x, 28x, 45x     Electrical Requirements: 100-240 VAC, 50/60 Hz, 800 VA
