Kodak - DirectView CR 825
The Kodak DirectView CR 825 system is a robust and reliable CR system that is ideal for lower volume hospital departments, remote clinics, and orthopaedic applications. This single-cassette system uses the same rigid cassettes as the Kodak DirectView CR 850 and 950 systems, enabling processing to occur at any location convenient to radiographers and patient care.
FORUMSView All (3)
0Repliesa year ago | Recovery of system How to correct Java.lang.ClassCastException Equipment: Kodak - DirectView CR 825 Reply |
1Reply3 years ago | Anchorage Cut sheet Hello: As we are using this CR reader, we would need to anchore thie CR reader for our hospital renovation project, so we are wondering if you guys have any of the Seismic Brackets as well, the H177_0137BCA, H177_0137BC, H177_0138BCA and H177_0128BC. Thank You. Lewis Reply |
5Replies7 years ago | kodak directview cr 825 Need ID and password for service system kodak directview cr 825 Reply |
- Based on proven DirectView CR 850 system design
- Process up to 62 35 x 43 cm plates an hour
- Small footprint size of 25 x 29 inch (63.5 x 73.6 cm)
- Rigid plates and cassettes: 100% non-contact scanning and long life expectancy
- Intuitive user interface consistent across all Kodak DirectView CR and DR systems
- Integrated PC capable of storing up to 2,000 images
- Integrated bar-code reader for patient/cassette/exam identification
- Integrated “on-line” intelligent UPS provides continuous clean power to system as well as battery support during power outages, allowing the CR 825 to complete current processing (including image save) before performing an orderly shutdown
Height | 59.5 in |
Length | 29 in |
Weight | 528 lbs |
Width | 25 in |
Throughput: 62 cassettes per hour (35 x 43 cm)
Time to first image: 53 seconds
Monitor: 15.0 in. flat-panel, touch screen, full color (1024 x 768 matrix)
Power: 100-120 VAC 10 Amps 50/60 Hz; 200-240 VAX 5 Amps 50/60 Hz
Heat dissipation: 1400 BTU/Hr max
