Hillrom - Advance Series
by Hillrom
0Replies5 years ago | Err0 hill rom I have an err0 showing up, according the service manual, the analog board is the culprit of this error, so already replaced the board, but no chang still err0 showing, does anyone have any idea if what could this be? Reply |
7Replies7 years ago | Head board does not raise up When I push the button, I can here the motor running, but the head board will not raise up. I can pull it up manually. Someone told me the problem might be the fuse? If so, where is the fuse located? Reply |
9Replies8 years ago | service manual Does anyone have a pdf of a Hill-Rom advance series bed service manual you could send me?Reply |
[list] [*] Three motors [*] High-low travel time: 21 seconds [*] Central pedals for braking and steering [*] Automatic night light [*] Instant CPR release [/list]
Height | 17 in to 30 inches |
Bed Type | Electric |
Length | 93.5 in Fully extended |
Width | 41.5 in with siderails up |
Sleep surface: 36” (w) x 82” (l) Bed frame clearance with 5” casters: 7.5”
