CareFusion - Alaris SE 7130
by CareFusion
he Alaris® SE pump is a single and dual channel stand alone large volume pump. The Alaris pump "Gold" model supports the Guardrails® Suite MX software. This is the same software that is used in our state-of-the-art Alaris System. This software is the most complete safety solution available today at the point of care for large volume infusions and helps provide unprecedented protection for caregivers and patients using a "smart" pump.
The Alaris SE pump offers advanced features including IV system monitoring. The IV monitoring system incorporates the exclusive resistance, high resistance and pressure modes, and maual baseline option. With rapid time to alarm, and the ability to filter out infusion artifacts such as flow rate variability and patient motion, the system provides real time intravenous monitoring. In addition, the Alaris SE pump offers advanced programming options like Loading dose, Multi-step, and Multi-dose. These programming options can save nursing and pharmacy time and reduce costs.
All Alaris SE pump sets feature the AccuSlide® Flow Regulator. The AccuSlide minimizes the risk of free-flow with an integrated flow stop, which automatically closes, when the set is removed.
0Replies7 years ago | "instrument malfunction" Carefusion Alaris SE Did anyone know the exact culprit of error "instrument malfunction " in ?sometimes the error persist even after the main PCB replaced.Reply |
Volume to be Infused | 0 to 9999.9 |
Height | 8.6 in |
Length | 5 in |
Flow Rate Range | 0.1 to 9999.9 ml/h |
Weight | 8.4 lbs |
Width | 10.5 in |
Power Requirements: 100- 120 V~,50/60 Hz, 0.5A,3-wire grounded system (40 watts Max)
