B. Braun - 360 Infuser
by B. Braun
B. Braun 360 Infuser
Continuous intravenous infusion rates up to 360 mL/hr, depending upon syringe size; Water-resistant plastic case; can be hung on a pole or use optional pole mount; can be used as primary Infusor or can deliver downstream secondary piggyback infusions. Variable time setting using digital controls; LCD display shows time remaining; uses 4 C-cells.B
Flow Rate Range1.5 to 360 ml/h
Delivery Time: 10 - 60 min. in 2.5 min. increments    Accuracy: ± 3%    Occlusion Limits: Dependent upon syringe size    Battery Life: 400 hours typical, 10 hours on Low Battery
