Pharmacia LKB - Ultrospec 2000
by Pharmacia LKB
Spectrometer
Pharmacia Ultrospec 2000 UV/VIS Spectrophotometer measures standard absorbance, concentration and transmittance. The full wavelength range for both UV and visible. Holds a single cuvette.
-GDumais
Wed Jul 13 2022
Spectrophotometer
Hi! I am looking for a way to validate the results of the spectrophotometer are accurate. We have two device, the pharmacia Ultrospec III and the DR2010 HACH. Do you know any filters or methods that could help to demontrate that the devices are accurate. Thank you for your time! Reply
-JUN P. MORADOS
Tue Dec 06 2016
Ultrospec 2000 service manual
we need service manual of the said subject Ultrospec 2000
thank you.
  • Range wavelength: 190-1100 nm
  • Precision wavelength: 1 nm
  • Reproducibility wavelength: 0.5 nm
  • Zero drift: ±0.002 A/hr
  • Watts: 150 VA
  • Linearity wavelength: ±0.5%
Height19 cm
Length 36 cm
Weight13 kg
Width50 cm
  • Dimensions (H x W x D): 19 x 50 x 365 cm
  • Weight: 13 lbs.
