A dec - 400 Dental Chair
by A dec
Dental Chair
Instead of sacrificing ergonomic access to the oral cavity for patient comfort, get both with the A-dec 400 dental chair. Patient comfort is paramount in reducing anxiety. The A-dec 400 dental chair design helps put patients at ease.
  • Ultra-thin backrest that "flexes" (1", 25 mm).
  • Enables you to tuck your knees under the chair providing ergonomic access to the oral cavity.
  • Double-articulating gliding headrests.
  • Adjusts easily for optimal patient positioning. Available in locking knob and lever release styles.
  • Full height range.
  • Offers a range from 13.75" to 31.25" (349 mm to 794 mm). Low point 14.75" (375 mm) with dual mounting.
  • 2-position armrests.
  • Combines comfortable arm/elbow support with a robust load-bearing design for easy patient entry and exit.
  • 60º swivel with brake.
  • Allows 30º rotation on each side of center.
  • Hybrid chair lift system.
  • Combines the power of a hydraulic base and the smoothness of an electro-mechanical tilt, allowing simultaneous movement for quicker patient positioning.
  • Integrated 300-watt power supply.
  • Provides more than enough power for the whole system; powers light and additional ancillary devices.
