Stryker - S3
by Stryker
Monitors the patient's position in three zones and 30-degree Head Of Bed angle
Stryker's S3 reduces the risk of ventilator-associated pneumonia. The bed also offers one-hand operation of siderails, center-mounted brake, one-touch in-bed scale and superior ergonomics to reduce bending and twisting that can injure caregivers.
FORUMSView All (19)
-LunaAGTI
Thu Aug 22 2024
Fowler actuator slowly lowers if weight is applied
I've had this issue a couple times now (3002 model) where, if the fowler angle is greater than ~17°, it slowly lowers until its flat when weight is applied. This doesn't occur at steeper angles. I've seen this a couple times now and so far I have just replaced the actuator but I was wondering if anyone else has encountered this issue and if there is anything I can be doing to help prevent this issue going forward?
-Ryans1987
Thu Nov 17 2022
MedSurg bed foot and head will not go up at the same time.
Have a MedSurg S3 bed that the head and foot will not go up at the same time when raising the head of the bed. Individually they are fine. I was curious if it was part of the programming on this particular bed that would not allow it to raise the foot up when I am raising the head.Reply
-T.M.B. Service
Tue Jul 27 2021
Error 601 - footborad screen
How to fix an error for a stryker 3002 S3, or reset the footboard to work on gateway CPU. NOTE: Incompatible Footboard. Reply
SERVICE COMPANIESView All Bed Companies
[list]       [*] Centrally-located brake pedal       [*] 4-wheel, steel brake with swivel lock system       [*] 6-inch (15 cm) casters       [*] One-touch 30 degree Head Of Bed angle and lock      [*] One-hand, intermediate siderails       [*] Retractable frame      [*] Open architecture—flat litter deck       [*] Fowler angle gauge       [*] Four IV pole and traction equipment sockets       [/list]
Bed TypeElectric
Length 93 in
Width43 in with siderails up
