Asclepion - MCL31 Dermablate
by Asclepion
The Erbium:YAG laser is the gold standard in dermatology when it comes to highly precise ablation. It allows the safe and gentle removal of a variety of benign lesions of the epidermis and dermis. It provides effective treatment for wrinkles and scars, such as those caused by acne, without any thermal damage to the skin, due to the high water absorption of its wavelength and the highly effective ablative and fractional technology. Its reliability and effectiveness have been proven worldwide. The MCL31 Dermablate Erbium:YAG laser ablates the skin with a degree of precision that can be measured in microns and can be carried out as a fully ablative or fractional process. This makes it possible to safely and gently remove a wide variety of lesions from the skin at epidermis and dermis level. It also allows both ablative and fractional skin rejuvenation. The wavelength of 2,940 nm of the Erbium laser matches the maximum peak of water absorption (water is the main component of the skin). The energy is therefore entirely used for the rapid vaporization of the water in the tissue, which leads to the almost instant ablation of tissue. Due to its characteristics, the MCL31 Dermablate has a significantly shorter healing time compared to a CO2 laser (time for re-epithelialization, erythema, edema). On the other hand, the CO2 laser results in better hemostasis thanks to coagulation. Thanks to the greatly limited thermal effects of the Erbium laser, the procedure is less painful than with CO2 lasers. Patients do not require any anesthesia in the treatment of small lesions. Side effects and risks are greatly reduced with this laser. The safety of this treatment makes the Erbium laser the superior choice for delicate areas such as the periorbital region or even the neck, chest and hands.
3RepliesWed Apr 07 2021 | Getting a "no simmer" error...pretty old laser, probably not much maintenenece. "No simmer"..... lamp? any ideas?Reply |
0RepliesSun Aug 16 2020 | Error code 1828 and 907. Machine can't use. The Error 1828 show scrren when start machine. The Error 907 show screen when push ready buttom. who can fix problem this? PLease let me know or Service Asclepion MCL31 tell me.Reply |
0RepliesFri May 08 2020 | Dermablet MCL31 is show erro 505. Dermablate show erro 505. i check problem from cable is wrong. I need service manual or introduce from you.Fix problem and diagram cable inside machien. Reply |
[list] [*] Integrated smoke evacuation system with triple-filter system [*] VarioTEAM handpiece with adjustable spot size directly on the handpiece [*] Adjustable pulse length [*] “Coagulation mode” keeps the treatment area free and clear [/list]
| Wavelength | 2940 nm |
Laser Type: Erbium:YAG
