Asclepion - TattooStar R
by Asclepion
The TattooStar R is extremely effective in the removal of tattoos, pigmented lesions and permanent makeup. Treatment using the TattooStar is quick, nearly painless, bloodless and highly effective, without causing injury or leaving scars. The ruby wavelength is the optimal wavelength for the removal of darker pigments such as black and blue. It is also effective in the treatment of green-colored tattoos. The ultra-short pulses of the Q-switched make it possible to burst the particles without any thermal side effects or scars. This increases patient comfort. The TattooStar can be operated for a long duration, even in regions with higher temperatures and higher humidity, at a maximum speed of 2 Hz. This makes it one of the fastest and most reliable systems on the market. Its unmatched power output enhances your application spectrum, in addition to providing you with greater flexibility and efficiency.
0RepliesSun May 30 2021 | Tattoo star problem Hello I have a problem in this laser "power supply error, code 901" I checked the device and almost every thing works well except the q switch, it does not receive the power it needs. Could you help , please . Thank you Reply |
1ReplyMon Jan 14 2019 | SERVICE MANUAL FOR ASCLEPION TATTOOSTAR Hi, how can i get a co[y of the service manual for this laserReply |
0RepliesFri Dec 09 2016 | Tattoo removal with the TattooStar q-switched laser by Asclepion The removal of tattoos with the q-switched laser is a very effective and precise treatment. For more information please visit www.asclepion.com Reply |
[list] [*] Q-switched ruby wavelength [*] Reliable, fast and powerful [*] Square-shaped spot with automatic spot size detection [*] Microlens array with “homogeneous spot” [/list]
| Wavelength | 694 nm |
