Stryker - Go II
by Stryker
This med/surg bed is easy to use and remarkably mobile. It answers the need for reliability, predictability and stability for patient care practices. Stryker’s GoBed II addresses caregiver and patient safety with low bed height, full coverage siderails and Stryker’s retractable fifth-wheel mobility. GoBed II offers superior mobility and versatility in any med/surg application.
1ReplyTue Sep 10 2024 | All lockout LEDs (padlock icons) flash Anyone know what the problem could be when the Lockout LEDs keep flashing? Thank you! Reply |
0RepliesWed Sep 08 2021 | Fowler Erratic movement My Stryker GoBed II Fowler lunges erratically on the way up and downReply |
0RepliesTue Oct 20 2015 | Bending Frames Has anyone encountered the GoBeds getting bent on the head side only during usage? I've had four turned in to CE and the frames are 3-4 inches out of square. I'm at a loss as to how that much pressure can bend those frames. Stryker will not honor this under their lifetime warranty. Reply |
[list] [*] BackSmart Design [*] Chaperone Bed Exit System [*] Integrated Scale [*] Open Architecture [*] Exceptional Low Height [*] Complete Siderail Coverage [*] Retractable Fifth Wheel [*] Intuitive Siderail Controls [*] Integrated Pump Holder [*] Cardiac Chair Positioning [*] Manual Back-up [/list]
| Height | 14.5 in low height |
| Bed Type | Electric |
| Length | 94 in |
| Patient Weight Capacity | 500 lbs |
| Width | 40 in with siderails up |
