Beckman Coulter - Allegra X-5
by Beckman Coulter
Clinical Centrifuge Systems.
Beckman Coulter's Allegra X-5 benchtop centrifuge gives a reliable performance under the most exacting standards for virtually any clinical sample preparations. It has a quick run setup with convenient, pre-bundled packages. The Aleegra X-5 is ideal for serum, plasma, and whole blood sample processing, protein precipitate, particulate and cell sedimentation, as well as in-vitro cytotoxicity and receptor binding sample processing.
-Jovy Ponciano
Tue Sep 25 2018
Removal of the tapered sleeve from the motor shaft.
How do you remove the tapered sleeve from the motor shaft? Do I use a pulley?Reply
[list]      [*] Robust drive system      [*] Motorized lid-locking system for easy loading/unloading      [*] Super-compact design saves valuable lab space      [*] Safe operation      [*] Process up to 140 x 13mm blood tubes and 100 x 16mm blood tubes      [*] Reduce run times with centrifugal forces up to 4,470 x g      [*] Safely process hazardous samples with optional BioCertified rotor      [/list]
Height39 cm with the door closed. 88 cm with the door open
Length 63.4 cm
OrientationBenchtop
Weight77 kg
Maximum Speed4700 rpm
Width49.6 cm
[list]  Ambient temperature range: 5 - 40°C      Set temperature: -20° to +40°C      Set time: 1 min. - 9 hr 59 min, (in 1 min. increments      Speed control: Actual rotor speed, ± 50 RPM of set speed  [/list]
