Beckman Coulter - Microfuge 20
Speed and versatility in a compact footprintFast, cool and versatile, the high-performance Microfuge® 20 Series are precisely designed to meet a wide variety of application needs including, nucleic acid preparation, pelleting, purifications, and more. Paired with Beckman Coulter Microfuge Series rotors, this mini-centrifuge series offers you all the flexibility you need for your separation protocols.
4Replies10 months ago | E 53 issue I have replaced the Locking Assembly and the Main Board Still getting E 53 after the lid is closed and locked into place Anyone ever have this issue? Reply |
- Four different rotor options from for ultimate flexibility
- Fast sample processing
- Spin more samples per run
- Efficient and easy-to-use interface displays both speed (rpm) and RCF (xg)
- Reduced setup time with user-defined programs for common lab protocols
Orientation | Benchtop |
Centrifuge Type | Microcentrifuge |
Maximum Speed | 15000 rpm 20,627 x g |
Maximum Capacity: 36 x 1.5/2.0 mL tubes
