Beckman Coulter - DxH 500
Ideal for pediatrics and geriatrics.The DxH 500 was specifically designed for physician offices and other laboratories with low-volume workloads.
FORUMSView All (5)
1Reply3 months ago | I need service manual The diluent expir But the all reagent new Equipment: Beckman Coulter - DxH 500 Reply |
1Reply5 months ago | ACHAT DES REACTIFS DU DXH 500 Bonjour P.ouvez-vous m'aider pour un approvionnement en réactif du DXH 500 à DJIBOUTI, Reply |
3Replies5 months ago | Barcodes for Diluent Lyse Cleaner Hi I need barcodes for Diluent Lyse Cleaner Can we exchange Reply |
[list] [*] 98.5% uptime [*] Quality clinical results from as little as 12 ΜL of sample [*] Change all three reagents in less than five minutes [*] Repeat testing on the same sample without another draw [*] Perform any command in three touches or less [*] Supports your efforts to go paperless with bidirectional LIS Interface [*] On board storage of 30,000 patient results [/list]
Height | 406 mm |
Length | 430 mm |
Weight | 11.4 kg |
Width | 270 mm |
