Beckman Coulter - CytoFLEX S
by Beckman Coulter
Flow Cytometer
The CytoFLEX S Flow Cytometer series is an expansion of the CytoFLEX Platform. The CytoFLEX Flow Cytometer offers three laser options, 488 nm, 638 nm, and 405 nm. The CytoFLEX S Flow Cytometer platform expands your research possibilities, with a fourth laser option, multiple configurations and unique filter sets for your science. CytoFLEX S Systems are available in preset configurations with up to four lasers, including 561 nm, 375 nm or lasers in the original palette and up to 13 channels for fluorescence detection. Just like the CytoFLEX, the CytoFLEX S utilizes the same advanced technology to deliver superior sensitivity and resolution, comparable to or even exceeding instruments four times its size. The CytoFLEX Platform has a unique flow cell design and integrated optics. The innovative Wavelength Division Multiplexing (WDM) detection module includes high efficiency, low-noise Avalanche Photo Diode detectors for excellent performance. The revolutionary system presents optimal excitation and emission, minimizing light loss and maximizing sensitivity. Innovative technology enables the detection of dim populations with a software interface that is easy to use. The CytoFLEX S is light (less than 22 kg) and compact (H 40.6 cm by W 40.5 cm by D 33 cm). You can install the CytoFLEX S where you need it on the benchtop or inside a standard biological safety cabinet.
| Height | 34 cm |
| Length | 42.5 cm |
| Weight | 23.4 kg |
| Width | 42.5 cm |
