Coherent - OPAL
by Coherent
Therapy Laser
When you work at different treatment sites, you need a laser that is easy to transport, install and link to a variety of slit lamps  without the need for a service engineer or recalibration. Only the Opal Photoactivator provides a user-installable clip-on, clip-off link to a variety of slit lamps. You can easily transfer the laser from one site to another without requiring a service engineer or recalibration. Just put the Opal Photoactivator in its carrying case, take it where you want to go, and set it up yourself.
FORUMSView All (5)
-ShelliWinter
Fri Feb 13 2026
Users Guide
Looking for the users guide.
Equipment: Coherent - OPAL
-MD Conway
Wed Oct 30 2024
Aiming Beam focus
Cannot get aiming beam in a circular spot it is a rectangle
-Amanda Byers
Fri Dec 15 2023
Error code F38, F39
Getting error code F38, F39 when turning on the laser. Anyone know how to resolve this?
  • Touch-screen user interface for safe, error-free operation— even in the dark
  • Automatic contact lens list adjusts laser energy for the magnification of the contact lens chosen. Look-up tables and manual entry errors are eliminated
  • Adjustable beam makes it easy to see through the slit lamp to the treatment spot over the lesion zone
  • Direct spot size entry permits adjustment while observing the beam on the retina through the slit lamp
Laser TypeDiode
Height5 in
Length 12 in
Weight7 lbs
Wavelength689 nm
Width7 in
  • Power to the Cornea: 5 – 300 milliwatts delivered to slit lamp focal plane
  • Retinal Spot Size: Up to 6400 microns
  • Aiming Beam: Red diode, 635nm
  • Electrical Requirements:100 – 230 VAC, 50/60 Hz, 110 W
