Biolitec - Diomed 630 PDT
by Biolitec
The Laser operates from a standard electrical wall socket and can be taken with ease from one location to another, enabling treatment to be delivered to the patient in the operating room or doctor s office. Using semiconductor diodes as the laser source, the DIOMED 630 PDT Laser emits light for use with drugs activated at 630nm such as Porfimer Sodium (eg Photofrin®) for the treatment of specific cancers. The laser energy is delivered by the OPTIGUIDE fiber optic delivery system, compatible with the majority of endoscopic instrumentation.
[list] [*] Quick to set up [*] Easy control of laser energy delivery by hand switch [*] An internal power meter for calibration of optical fibers, enabling accurate dosing of the patient [*] Automatic selection of laser energy dosimetry using the touchscreen menu, the operator simply identifies the treatment area and the fiber length to be used and the software calculates the laser power and duration required for each treatment [*] Software displays the power and energy delivered during each treatment session [/list]
| Laser Type | Diode |
| Height | 485 mm |
| Length | 405 mm |
| Weight | 19.5 kg |
| Wavelength | 630 nm |
| Width | 220 mm |
Power: 2000mW, imited by software Delivery Fiber Calibration: 400mW for 2 seconds Aiming Beam: InGaAlP (nominal wavelength 630nm) diode laser, 5mW at delivery fiber tip.Modes: On/Off/Flash Cooling: Forced air
