ZEISS - Visulas 532
by ZEISS
Effective and gentle retinal photocoagulation.
The VISULAS® 532 is a powerful, diode-pumped solid-state laser. Its built-in thermoelectric cooling system ensures excellent temporal stability of the laser power and thus meets the requirements for reproducible clinical results. The VISULAS 532 is designed in particular for retinal photocoagulation, trabeculoplasty and iridotomy for treatment of glaucoma. The VISULAS 532 with the VITE option is primarily useful for multi-spot panretinal and grid photocoagulation.
FORUMSView All (9)
-Giusimo
Wed May 21 2025
burnt power circuit
Hi everyone, I need the wiring diagram, because I have a burnt resistor and I don't know its value. Thanks
Equipment: ZEISS - Visulas 532 of the year 2001
-Francisco Moran
Wed Apr 30 2025
Error 35
When turning on the equipment, it displays Error 35, remains blcked and doesn't work
-Giusimo
Wed Mar 12 2025
service manual
I would need the service manual for the zeiss laser 532.
thanks in advance
best regards
[list]              [*] Gentle laser treatment - The ParFocus™ zoom system delivers a homogeneous, sharply defined and reproducible laser spot on the retina and minimizes heat-related side effects on the patient's cornea              [*] Significantly reduced treatment times - A linear sequence of up to 12 laser pulses can be triggered at the touch of a button on the slit lamp joystick              [*] Navigating with fingertip precision - The electronic micromanipulator allows sensitive, synchronous laser beam positioning and slit lamp illumination              [*] Solid performance in the operating room - A perfect duo together with the OPMI LUMERA® 700 surgical microscope              [*] True-to-color slit lamp image - The active ClearView™ safety filter not only protects the physician but also provides a true-to-color slit lamp image              [/list]
Laser TypeOphthalamic
Height150 mm
Length 400 mm
Weight14 kg
Wavelength532 nm
Width300 mm
[list]    Aiming beam: Diode, 620 to 650 nm, adjustable brightness (Max. 1 mW at the cornea)    Rated voltage and frequency: 100 V to 240 V, 50/60 Hz    Pulse duration (single pulse): 10 to 2500 ms, cw    Pulse duration (VITE option): 20 to 50 ms    Pulse interval (single pulse): 100 to 6000 ms    Max. power: 1.5 watts at the cornea    Cooling system: Thermoelectric    [/list]
