Cynosure - Revlite
by Cynosure
Revlite Laser
The Revlite is a Q-switched laser with 4 wavelengths (1064nm, 532 nm, 585 nm, 650 nm). Emitting high energy, it is most useful in the treatment of benign pigmented lesions (lentigines and sun spots) and in the treatment of tattoos. This laser emits its energy in a few nanoseconds and on impact with its target (pigment, either endogenous – melanin, or exogenous – tattoo pigment) causes the fragmentation of this pigment through a photomechanical/photoacoustic effect. The fragments of pigment created are then eliminated by the patient’s immune system, mainly through the lymphatic system.
FORUMSView All (6)
-J.Smith
Fri Jun 20 2025
Revlite power supply
When turning on the equipment, after 1 second, the Revlite power supply has a discharge noise (like a spark inside the power supply). Any suggestions please?
Planning to disconnect the power supply cables, discharge the capacitor, remove the power supply and visually inspect it, see if there are any components damaged, or if there are signs of burning or sparks.
-Fasullo
Tue Dec 12 2023
LCD Software
I'm looking for the SW corresponding to SD Card 439-9062 (Revlite LCD) Rev. H or H.1 or H.x
it is urgent
Thank you!
-Ahmed.alashkar777_8405
Fri May 20 2022
Lcd software
Can any one send me the revlite lcd software . For revlite and revlite si pleaseReply
[list]                  Applications:                  [*] epidermal pigmented lesions                  [*] dermal pigmented lesions                  [*] tattoos                  [*] multicolored tattoos                  [*] laser assisted hair removal                  [*] cafe-au-lait spots                  [*] age spots                  [*] nevus of Ota                  [*] Becker nevus                  [*] rejuvenation of the face                  [*] melasma                  [/list]
