Philips - Respironics BiPAP Focus
Ventilator
The BiPAP Focus Noninvasive Ventilator is a basic bi-level delivery system designed specifically for the institutional setting. Ventilatory assistance is provided to stable, lower acuity patients with respiratory insufficiency or failure. Compact and lightweight, the BiPAP Focus System provides features that make delivery of noninvasive ventilation easy and effective. Compact and lightweight, the BiPAP Focus System provides features that make delivery of noninvasive ventilation easy and effective.
FORUMSView All (5)
2Replies4 years ago | preventive maintenance can anyone provide preventive maintenance and performance test procedures?Reply |
3Replies5 years ago | negative flow calibration What is everyone using to generate the negative flow required for calibration?Reply |
1Reply6 years ago | BIOMED I need the calculation formula(LPM of oxygen) for the use of oxygen(%) in a Focus Bipap, how much flow from the external Oxygen flowmeter for a given %FIO2? depends on the patient Minute Volume.Reply |
- Digital Auto-TRAK™ Sensitivity - Like many other Respironics bi-level ventilators, the BiPAP Focus System includes Respironics proprietary Digital Auto-Trak Sensitivity. This feature assures optimum triggering and cycling sensitivity throughout changing breathing patterns and leaks. It also eliminates the need for a perfect seal of the patient interface and constant adjustment while promoting patient-ventilator synchrony.
- Large Use Interface - Designed for the hospital environment, the user interface is easy to use. It allows the practitioner to easily and quickly adjust patient care settings.
- Patient Parameters Display - This valuable feature conveniently allows the practitioner to view all patient parameters at once.
- Pressure Bar Graph - Quickly and clearly indicates patient breaths and pressure ranges.
- Easy-to-Use Alarms - Pressure alarms are automatically set to 5 cm H2O above IPAP and below EPAP settings, minimizing nuisance alarms and enhancing patient safety.
- Back-up Battery - An integral backup battery system maintains patient ventilation in the event of an interruption in power. This safety feature also provides a convenient method for intra-hospital patient transport from one care area to another with uninterrupted ventilatory care.
- Total Ventilation Solutions - The BiPAP Focus Ventilator is part of our Total Ventilation SolutionsSM that help treat, monitor and manage respiratory-impaired patients.
