Hitachi Medical Systems - Sirius HP/HT 130
Easier for the operator to use and also gives a relaxed feeling to examinees.The human mobile X-ray system, in which “easiness” and “friendliness” are incorporated as results of pursuing high function and operability for smooth examination, is Sirius 130HP.
Mobility is on of the most important factors for mobile X-ray unit. The unit can be slowly , speedily and smoothly driven through a narrow space, and stopped precisely , providing queit and excellent driving operability.
FORUMSView All (6)
0Replies9 days ago | Error code 3 Hello, Would you please provide me with service manual or at least the error codes list for : Hitachi Srius Ubiquitas X-Ray unitWe are having Error 03 as soon as you start the machine.Thank you so much in advance Equipment: Hitachi Srius Ubiquitas Mobile X-ray unit Reply |
0Replies3 months ago | error 3 how to solve the error 3 Equipment: Hitachi Medical Systems - Sirius HP/HT 130 Reply |
0Replies2 years ago | Error 06 Hitache siruis 130hp error 6 , and if can i need service manual.Reply |
SERVICE COMPANIESView All Mobile Radiography Companies
- Touch Sensor for Safety - A silent design motor and cushion casters are adopted to stop the system from making a loud noise when travelling. Useful for travel during the night and for shock absorption when going over steps.
- Wide Frontal View - The wide frontal view is ensured even if for a short-heighted operator thanks to not only a slim body design but also eliminated high voltage cable in a mono-tank and a low-mounted X-ray tube assembly.
- Swiveling Mechanism of the X-ray Tube Assembly - Even when the arm is at a tilt, the body axis of the patient and the axis of the x-ray tube assembly can be matched with this mechanism. This is an indispensable mechanism for fine positioning.
- Effective positioning, adjusting the switch - Fine adjustment of the cart positioning is possible using the adjusting switch positioned on the remote panel while carrying out positioning. Contributes to shortening the time necessary for doctor’s rounds.
