Axia Surgical - TRIA
The Axia TRIA is a new and intuitive approach to patient vital signs measurements.
The TRIA can be configured to measure any combination of: non-invasive blood pressure, SpO2, rapid temperature and capnography (EtCO2). The TRIA is well suited for any patient care area by offering a multitude of vital sig combinations. The TRIA can be used as a basic pulse oximeter or configured to a NIBP / SpO2 / Temp spot check monitor. The TRIA can also be configured to be a stand alone capnograph or a combination capnograph SpO2 / NIBP monitor. The TRIA is well suited for bed side and mobile spot check use.
3Replies4 years ago | Screen not turning on Attempting to contact Axia Surgical for several month regarding monitor repair. Second unit that screen stopped working after minimal use. Trying to return for refund. Reply |
- Touch screen
- Simple interface
- Intuitive
- Long life Lithium Battery
- Mobile (Backup battery powered)
- Portable (weight 1.71 lbs)
- Color waveforms
Applications
- Neonatal
- Pediatric
- Adult patients
Height | 8 in |
Length | 4 in |
Pulse Rate Range | 30-250 BPM |
Weight | 2.5 lbs |
SpO2 Range | 0-100% |
Temperature Range | 86 to 109 °F |
Width | 4.5 in |
