ZEISS - MEL 80
When you want to see better performanceThe MEL 80 is a top quality Carl Zeiss Meditec product, designed to make the correction of vision defects even safer, more patient-friendly and individual. All the parameters of this ultramodern work platform are oriented towards increasing efficiency, achieving optimum treatment results and the rapid recovery of vision. Key factors here are the extremely fast ablation, customized treatment planning with the optional CRS-Master, the high-performance eyetracker system and the "Eye Registration" torsion compensation system.
0Replies13 years ago | asa please give me more details on asa, berclas and tsa and 7 super60Reply |
[list] [*] The exceptionally fast MEL 80's short ablation time reduces procedure time for greater patient comfort [*] Shortened stroma exposure time means faster visual recovery [*] Very small 0.7 mm spot permits the finest corrections without losing the benefits of smooth ablation [*] Two specially optimized ablation profiles to choose from help you produce excellent results [*] An active eyetracker with excellent feedback times and an ultrarapid IR camera catching both pupil and limbus provides exact positioning during the laser treatment [/list]
Laser Type | Excimer |
Height | 58.7 in |
Length | 61 in |
Weight | 260 kg |
Wavelength | 193 nm |
Width | 31.5 in |
Frequency: 10 / 250 Hz depending on treatment mode Aiming beam diode: 650 nm Cooling: Air, noise-reduced
