Seca - 763
by Seca
Digital weighing and measuring station with automatic BMI calculation
With the digital measuring and weighing station seca 763, both the height and weight of a patient can be obtained in just one step. After measuring and weighing, both values are indicated on two LCDs integrated into the display panel. On the basis of these values, the seca 763 automatically calculates the BMI of the patient at the touch of a button. This provides information on the general nutritional condition of the patient on the basis of the recognized WHO standard. With a capacity of 550 lbs, the slip resistant base and anti-tip column design makes measuring and weighing a safe procedure for heavyweight patients.
-Big Daddy Daz
4 years ago
testing / calibration
Hi, I have responsibility for a number of these class 4 scales. can anyone advise on service procedure / routine testing. If the service manual was available this would also be really helpfull. Thanks in advance. Reply
-shaima
8 years ago
seca 763 error
Hi, my seca 763 is showing an error Er:5:93 when measuring the weight.. what i should do ?
  • Scale with integrated digital measuring rod
  • Determines weight, height and BMI in one single process
  • Large and clear LCD figures for easy-to-read results
  • High capacity of 550 lbs
  • Low-level platform with slip-resistant base and anti-tip column design
Height84.6 in
Length 27.2 in
Weight36.8 lbs
Width14.2 in
Capacity: 550 lbs
Graduation: 0.1 lbs
Measuring Rod Range: 43 - 79 inch
Dimensions Platform: 13.2W x 3.1H x 13.6D inch
Display Height: 52.0 inch
