Baxter - Phoenix X36
The PHOENIX X36 Hemodialysis Delivery System is intended to be used to provide high-flux and low-flux hemodialysis, hemofiltration, and ultrafiltration on patients weighing 15 kg or more. With features such as real-time Kt/V monitoring through the DIASCAN Monitoring System, compensated blood flow, full-color touch screen, and sodium and UF profiling, the PHOENIX X36 Hemodialysis System is designed to help provide effective hemodialysis therapy.
0Replies5 years ago | BP Board failing Our BP board has started failing more often with these machines and the boards are pricy at over 2000 dollars. Does anyone know of a better price out there or a place to order parts to repair the board?Reply |
[list] [*] Machine safety tests at the beginning of each treatment [*] Safety tests performed every morning [*] Calibration of the UF system performed during treatment [*] Testing of the DIACLEAR Ultrafilter membrane [/list]
Height | 56.7 in without IV pole |
Length | 27.9 in base |
Weight | 264.5 lbs Dry Weight |
Width | 24 in |
