Stryker - Bari 10A
by Stryker
Optimal comfort and an overall aesthetic that affords patients the dignity of a standard hospital bed look
Expandable length and width contribute to patient comfort as well as easier transports for staff. The Bari 10A is a true 1000 lb. weight capacity bed that has a strong, durable steel frame that promotes safety for both the patient and caregiver. Combine a low air-loss surface, Arise 1000, with Bari 10A to help prevent skin breakdown from pressure, friction and moisture. [list]
-rfahey
Fri Apr 08 2016
weight function
need instructions on weight function unable to access manual
[list]             [*] True 1000 lb weight capacity             [*] Expandable length and width             [*] Aesthetically pleasing             [*] In-bed scale             [*] Easy release siderails             [*] BariMatt 1000 foam surface             [*] Arise 1000 low air-loss surface             [/list]
Height34 in High, Low- 18.7
Bed TypeElectric
Length 90 in min, max-98
Weight700 lbs
Patient Weight Capacity1000 lbs
Width39 in min, max-52
