Bio-Rad Laboratories, Inc. - xMark
Spectrometer
The xMark Spectrophotometer is also flexible enough to read all standard microplates, from 6- to 1,536-well formats. Using Microplate Manager Software, the xMark Spectrophotometer can perform a wide range of end-point and kinetic applications with spectral scanning within low UV to infrared wavelengths. Extensive data analysis includes comprehensive curve-fit models and automated data export in single-plate or batch formats.
- Monochromator-based system for maximum optical efficiency and flexibility in photometry reading
- Spectral scanning to define the best absorbance wavelength for assays
- Imaging capabilities for pixel intensity data in a single well or entire plate
- Ability to scan custom plates
- Flexible control and data analysis with PC or Mac software
- Incubator with programmable temperature control
- Compatible with 6- to 1,536-well and custom microplates 128 mm L x 88 mm W
- Plate height cannot exceed 21 mm
- Clear flat-bottom plates are recommended such as Bio-Rad's Costar 96–Well Flat–Bottom EIA Plate (2240096)
- U-Bottom plates can be used, but V-bottom plates are not recommended
Height | 21.9 cm |
Length | 44 cm |
Weight | 27.5 kg |
Width | 54.4 cm |
- Wavelength range: 2001,000 nm
- Photometric methods: Single and dual wavelength
- Bandwidth: 5nm
- Imaging resolution: 0.5, 0.75, 1.0 mm
- Reproducibility:96-well plate; 1.0% or 0.005, 03.0 OD at 405 nm
- Stability and drift: 0.010 at OD = 1 at 490 nm
- Maximum plate height: 21 mm
