Bio-Rad Laboratories, Inc. - NGC 100
NGC™ 100 Medium-Pressure Chromatography SystemsThe family of NGC Medium-Pressure Chromatography Systems fit your throughput requirements when purifying biomolecules for analytical- and preparative-scale applications. Each system is composed of interchangeable modules that confer different system capabilities. The six preconfigured NGC Liquid Chromatography Systems listed below are designed with increasing automation and throughput to serve a wide range of laboratory needs
[list] [*] The guided fluidics selection tool (patent pending), coupled with the module discovery system, enables a single-click application-based system setup through automated module function recognition [*] The Tier Rotate™ Feature allows optimal placement of valves and detectors to minimize the flow path [*] Compact footprint — fits in a refrigerator, lab bench, or coldroom [*] Point-to-Plumb™ Feature shows the step-by-step plumbing of the system using LEDs [*] ChromLab™ Software provides powerful system control, automated methods, and analysis options [/list]
