Joerns - Easy Care 2000 XL
10 1/2 inch travel range - from 12 1/2 to 23 inchesAdjustments are made using "shin-friendly" cranks that drop out of the way when not in use. The sleep surface is 35 inches wide by 76 or 80 inches long and has a 500 pound operating capacity.
0Replies2 years ago | Pendent I have changed the pendent but it continues to flash. How do i correct this problem? ThanksReply |
1Reply8 years ago | LEGS LOCKED OUT THE LEGS TO THE BED ARE IN THE BENT POSITION. THE BED AND CONTROLER ARE LOCKED.. HOW DO I UNLOCK THESE? I TRIED HOLDING TWO BUTTONS AND UNPLUGGING THE BED WITH NO RESULT. Reply |
SERVICE COMPANIESView All Bed Companies
[list] [*] Manual bed [*] A 10 1/2 inch travel range - from 12 1/2 to 23 inches. [*] Adjustments are made using "shin-friendly" cranks that drop out of the way when not in use. [*] Sleep surface is 35 inches wide by 76 or 80 inches long [*] 500 pound operating capacity. [/list]
Bed Type | Manual |
Length | 76 in to 80 |
Width | 35 in |
Mattress Deck Height: 12.5" to 23"
