Joerns - Ultra Care XT
by Joerns
Through a remarkable combination of performance, function, and style, the UltraCare XT can be easily transformed to fit any configuration or room style.
0RepliesMon Aug 05 2024 | REMOTE CONTROL ISSUE My Joerns Ultra Care XT bed has managed to lock only the "lower legs" button on both remotes. It will not reset by pushing both the hi lo buttons at the same time. No lights are flashing, but I can not lower the foot/leg portion of the bed. It will only raise up, and the lock button only shows when I try to lower the feet/legs next to the lower foot/leg button on both the foot of the bed panel and on the handheld remote. How do I reset this? (Joerns hospital bed serial number #974689349775953460) Reply |
1ReplyThu Mar 29 2012 | side rails I recently purchased a electric bed for my son with cerebral palsy ,from a discounted furniture store here in belton Mo but there were no side rails.Is there any replacement rails that would work on this bed ,I really need to make sure he is secure ? Reply |
[list] [*] Toroidal architecture engineering of the bed’s steel frame is up to 30 times stronger than angle iron [*] Therapeutic grid surface offers improved air flow and ultimate support for the sleep surface [*] Integrated pendant connections on both sides of sleep platform [*] Four-section sleep surface offers full range of comfort and therapeutic positions, which may reduce skin shear [*] Attractive bed panel options available in a wide array of designs and finishes [*] Staff control allows caregivers flexibility to select which features may be adjustable by the resident (option) [*] EasyLift Leg Lift provides quick positioning for improved circulation [*] Revolutionary arched legs deliver a super-strong, wide stance for equipment clearance [*] Four DC motors supply amazingly quiet and smooth operation [*] 7-inch to 30-inch travel range offers safety, whether resting at an ultra low eight or providing care at the higher end [*] Assist devices have superior functionality and perfect grip height [*] Sculpted button on assist device for easy,“press and go” operation [*] UltraLock is available at the foot end or both the head and foot to maximize security or mobility at any height (option) [/list]
| Bed Type | Electric |
| Length | 80 in |
| Weight | 220 lbs |
| Patient Weight Capacity | 500 lbs |
| Width | 35 in |
Underbed Clearance:23.75 in. Sleep Surface Travel Range:7 in. to 30 in. Maximum Back Angle:65 degrees to horizontal Maximum Knee Angle:35 degrees to horizontal Maximum Knee to Leg Angle:45 degrees
