Cardinal Health - Pulse Wave® System
by Cardinal Health
Every detail of the Pulse Wave® Laparoscopic Suction/Irrigation System is designed to enhance speed, e ciency and ease of use with simple “plug-and-play” setup. The system includes the compact Pulse Wave® Pump, designed for optimal flow; the handheld trumpet valve, featuring fingertip control of fluid flow and colored valve buttons for easy differentiation between suction and irrigation; the Pulse Wave® Cassette for a quick and easy connection to the pump; a complete array of probe options, which can be interchanged in seconds; a single- or double-spike design for added procedural flexibility; and Primeflo® Insufflation tubing.
[*] Compact, quiet pump delivers gentle pulsating [*] Variable flow settings are easily adjusted from low to high [*] A complete array of probes provides clinical versatility- Probes can be interchanged in a matter of seconds [*] Soft, drapable, conjoined tubing helps prevent coiling within the surgical field [*] Plug- in cassette allows for quick and easy setup and takedown [*] Universal compatibility with existing fluid bags and suction canisters increases cost effectiveness
