Hologic - Aquilex
Fluid Management SystemThe high performance Aquilex system helps you maintain maximum control of your procedures. The system's innovative technology and design minimizes procedure time by rapidly achieving and maintaining distention independent of hysteroscope diameter. This can lead to a reduced length of anesthesia and lower risk of intravasation, while providing optimal visualization to the surgeon.
FORUMSView All (6)
2Repliesa year ago | error foung an abnormal scan condition was found code[0xc09000] dev[0x00140000] pno[800] Equipment: aquilion 16 Reply |
0Replies2 years ago | Scale error on boot up. New device right out of the box saying scale not connected. Tried other device on same scale set up error persiste. What should be looked atReply |
[*] A simple user interface that is easy to setup [*] Setup in three easy steps once the system is connected and powered on [*] One integrated system with a fluid pump capable of 800 ml/min inflow [*] Two integrated vacuum pumps (1 for the underbuttock drape and scope outflow, 1 for the MyoSure system) capable of producing up to 500 mmHg of suction [*] Automatic lumen calibration to optimize intrauterine pressure for achieving and maintaining distention and visualization with a wide variety of hysteroscopes
[*] A non-weight-based inflow volume measurement system that eliminates the risk of inaccurate deficit readings caused by sensitivity to movements such as bag changes or accidental bumps [*] The ability to add or remove bags without pausing the system [*] A system pause function that stops both inflow and suction pumps and locks the fluid deficit reading when a canister change is necessary, to eliminate inaccurate deficit readings
