Kinetec - Breva
Continuous Passive Motion Unit
The Kinetec Breva provides anatomically correct motion to the ankle and rear foot. It can be used in bed or while sitting in a chair.
[list] [*] Two dimensional movements possible: > Plantar Flexion 40° to Dorsiflexion 30° > Eversion 25° to Inversion 25° [*] Advanced hand control to maximise programs and protocols [*] Passive mobilisation of the following fractures after internal fixation: > Malleolar fractures > Tibial pilon fractures > Talar fractures > Calcaneal fractures [*] Warm-Up: Offers the patient a gradual progression to the pre-set full ROM. [*] Modulation: Allows manual setting of the ROM end-point based on patient tolerance. [*] ROM By Pass: Allows bypassing the pre-set ROM end points during the current treatment session. [*] Programme: Allows set-up of up to 16 customised programmes. [*] Timer: Adjustment of the session time. [*] Force: Work out of Concentric / Eccentric. [*] Pause: Adjustable in extension or flexion limit. Allowing the rest or the posture. [*] Mobilisation of the joints of the foot after operative or conservative treatment of lesions of the: > Achilles tendon > Lateral collateral ligament > Medial collateral ligament > Surgical lengthening of the Achilles tendon for post-traumatic stiffness. [/list]
Height | 56 cm |
Length | 45 cm |
Weight | 12.5 kg |
Width | 37 cm |
Foot sizing: 19 cm to 29 cm Speed: 50° to 150° per minute Voltage: 100 to 240 Volts 50/60Hz
