Kinetec - Spectra
Continuous Passive Motion Unit
[list] [*] LIGHT - Only 12 Kg (26 pounds). Provided with two handles transport board. The Kinetec Spectra is very easy to transport for a use in the hospital or in cabinet. [*] DIGITAL ADJUSTMENT - For all versions of the Kinetec Spectra, the remote control is easy to use and intuitive, that allows a precise and quick adjustment of the movement parameters. [*] PATIENT FEEDBACK - The large LCD screen shows the immediate and the programmed range of motion allowing a patient stimulation. DIGITAL ADJUSTMENT: [*] Warm Up: The patient reaches gradually the pre-set full ROM [*] Modulation: Allows manual setting of the ROM end-point based on patient tolerance. This mode is generally used at the beginning of the session [*] ROM By Pass: Used during the session, this mode allows a manual setting based on new patient tolerance, thus offering a real progressive work of the Range of motion [*] Force: This security feature allows the patient to reverse, more or less easily, the movement by a simple muscular contraction [*] Timer: Control of the session time [*] Programme: Allows set-up of 16 customised programmes [/list]
Height | 33 cm |
Length | 95 cm |
Weight | 12 kg |
Width | 33 cm |
Range of motion: -10° to 120° Speed: 45°/minute to 155°/minute Patient sizing: 1,45m to 1,95m - Full leg: 71 to 99cm - Tibia: 38 to 53cm - Femur: 33 to 46cm - With paediatric foot plate (in option): - Full leg: 53 to 109cm - Tibia: 20 to 56cm Maximum user weight: 135 Kg Voltage: 100 to 240 Volts 50/60 Electrical power: 20W
