Curlin Medical - 4000 Plus
by Curlin Medical
The Curlin 4000 Plus Pump is a multi-therapy ambulatory electronic infusion pump designed and manufactured for pain management or labor and delivery in hospitals.            The Curlin 4000 Plus Pump is an easy-to-use, ambulatory or pole mounted infusion device designed to meet the needs of the hospital or alternate site patient. It operates accurately in any position, has a low rate resolution of 2 microliters, and its small, compact, lightweight design allows mobility for ambulatory patients.            The Curlin Medical pump can be carried in any of the four convenient carryall soft-packs, pole mounted, placed into the locked “safety shells,” or set on a suitable surface for use.
-Valiaparambil
a year ago
Curlin pca pump
I have one curlin pump 4000 when we try to enter new program requesting  passcode. Can you please help me
[list]      [*] Continuous Infusion—Designed to allow a constant, programmed rate of infusion.      [*] PCA or Patient Controlled Analgesia—Designed for therapies that require a continuous rate of infusion, patient-controlled demand boluses, or both.      [*] TPN with Automatic Ramping—Designed to allow a level rate of infusion of parenteral nutritional products with the option of tapering at the beginning, end, or both beginning and end of the infusion. This mode also has an early ramp-down feature.      [*] Intermittent Delivery—Designed to deliver programmed intervals and rates of specified amounts of infuses and to optionally deliver small amounts of the infuscate between doses to keep the patient’s access site patent.      [*] Variable Program—Designed to allow varying amounts, rates, and times of delivery of infusions up to twentyfour specified programs.      [/list]
