Hospira - Plum 360
by Hospira
With today’s hectic pace, tight budgets and patient safety concerns, you need an infusion pump that serves both you and your patients, helping to maximize valuable resources and enhance your clinical practice. You’ll find the Plum 360 infusion system is unlike any other, with a unique combination of features that empowers you to deliver optimal healthcare – today and tomorrow.
2RepliesFri Jun 26 2026 | plum 360 issue is there a fix for this alarm message on a plum 360....Power Off then On. Replace pump if alarm continues. Reply |
1ReplyTue Jun 23 2026 | Technical Service Manual Hello- Is there an available Technical Service Manual for the Plum 360 of which can be referenced? Respectfully. Equipment: Plum 360 Reply |
1ReplyTue Jun 16 2026 | Intermittent proximal/distal occlusion alarms on Plum 360 IV pump despite line verification Intermittent proximal/distal occlusion alarms on Plum 360 IV pump despite line verification, back-priming, sensor cleaning, and testing with multiple cassettes. Looking for troubleshooting advice before replacing the pumping mechanism/module. Possible cassette compatibility, sensor calibration, or pressure sensing issues? Equipment: Plum 360 IV Pump Reply |
[list] [*] Air Matters — the Plum 360 utilizes the unique PlumSet™ cassette that features air management that doesn’t require disconnecting from the patient [*] Remove air faster — use the pump to automatically remove air through the cassette’s secondary administration port without disconnecting the line from the patient [*] Reduce therapy interruptions — capture 1 mL of air in the cassette’s air trap – an industry exclusive feature – before the alarm is activated [*] Reduce risk of contamination — Help eliminate the potential for contaminants by keeping the patient line connected [*] Secondary Delivery is of Primary Importance — Hospira’s Plum infusion systems are unique in the way they connect the secondary line directly to the PlumSet cassette, so the pump can differentiate between primary and secondary infusion lines and deliver each as intended [*] Optimize Safety and Compliance at the Point of Care — when programming your Plum 360 infusion system with Hospira MedNet™ software, you automatically start in the drug library [*] EMR Ready, Today and Tomorrow — when you and your electronic medical record (EMR) partner are ready for integration, your Plum 360 infusion system with Hospira MedNet safety software is ready too. Whether it’s today, or any time after, Hospira’s IV [*] Clinical Integration solution will connect your Plum 360 system to the medication order, patient information and EMR [/list]
