Smiths Medical - HL-1200A
The Hotline HL-1200A Rapid Infuser is a fast flow rate fluid warmer. With the D-300 disposable tubing the flow rate can be from 30ml/min to 1100ml/min with a maximal rate of 1400ml/min. The temperature of the fluids delivered to the patient is between 36-40 degrees Celsius and depends on the rate of infusion. The gas vent filter is designed to remove micro bubbles of gas from the line that results from the IV fluids being heated.
[list] [*] Mounted pressure chambers allow fast and easy bag changes. [*] Accommodate standard blood and crystalloid bags. [*] On/Off toggle switch automatically pressurizes chambers to a constant pressure of 300 mmHg. [*] Aluminum heat exchanger transfers heat 1000 times faster than plastic. [*] Counter-current recirculating a solution at 42° C providing an effective and stable heating. [*] Disposables are easy to insert and remove. [*] Gas vent/Filter Assembly can be changed without replacing the entire disposable. [*] Durable surface makes it easy to clean. [*] Roller wheels on base make it easy to transport within your facility. [/list]
Height | 67 in |
Length | 20 in |
Weight | 63 lbs |
Width | 20 in |
