Mindray - A7
by Mindray
Mindray A-Series Anesthesia Delivery Systems help you manage complex challenges with an intuitive, easy to use, safe and reliable approach to anesthesia delivery. The new A7 Anesthesia Workstation takes the popular A-Series to a higher level. The feature-rich A7 combines traditional bellows driven ventilation with electronic fresh gas technology providing effective care across a wide range of patients.
-MedWrenchFan#1
2 months ago
Default setting and alarms changes
I have the configuration password; how do I change the default parameters? Do I need a specialized usb?Reply
-S. Dubin
5 years ago
low pressure or not
Does this machine need a low pressure check like the GE machinesReply
  • Electronic gas flow with easily customizable settings and direct flow or total flow options
  • Quick keys for changing O2 flow
  • Low flow optimizer provides visual indication of efficient fresh gas flow setting, supporting the patient while reducing cost and waste gas
  • Agent usage calculation feature displays amount of agent used with each case
  • Automatic system compliance and fresh gas compensation
  • 15” color LCD touchscreen with control pad
  • HL7 connectivity for AIMS and EMR data export
Height140 cm
Length 80.5 cm
Weight185 kg
Width105 cm
