STERIS - Amsco 400 Medium
by STERIS
The AMSCO 400 Series® Medium Steam Sterilizer is designed for performance in today's sterile processing environment and is AAMI ST-8:2008 compliant. It's built to process 47% more instruments by weight. The AMSCO 400 Series Medium Sterilizer is validated to safely sterilize heat and moisture stable materials in packs up to 25 lb. This allows you to efficiently handle high-volume sterilization and heavier trays, while meeting today's stricter compliance guidelines.
1Reply7 years ago | Service Manual or Door PM procedure Steris series 400 medium Sterilizer does anyone have a PDF of the service manual for this unit? I sure could use the PM procedure section on the door. Matthew.Duvall@scasurgery.comReply |
