Chattanooga - Vectra Genisys
The first modular therapy system that consolidates up to six therapeutic modalities in one system at a fraction of what these modalities would cost.Vectra Genisys Therapy System is the only device to provide all modalities needed in the clinic: Electrotherapy, Ultrasound, Combination, Laser, sEMG and sEMG Activated Muscle Stimulation. Unique modular design lets users choose what best fits in a clinical setting now or can be easily added later without the replacement of products.
Feature rich software and advanced engineering, Chattanooga's Vectra Genisys gives direct control over multiple parameters so users can program treatments to meet even the most complex challenges. The user-friendly interfaces and intuitive on-board software provides the ultimate in ease of use.
All ultrasound and laser applicators are interchangeable and feature Electronic Signature for automatic recognition by the unit. Simply plug them in and go. Additionally, ultrasound applicators have a head warming feature for patient comfort and are waterproof for underwater treatments.
FORUMSView All (7)
1Replya month ago | User Manual How can i get a copy of the user manual for Chattanooga Group- Vectra Genisys, Model #2784? Equipment: Chattanooga Group- Vectra Genisys, Model #2784 Reply |
2Replies4 years ago | Power supply 100W for XT and Genisys 27048 El equipo tiene dos fuentes de alimentación, una fuente de alimentación de entrada universal de 100 vatios proporciona la placa de control y otra a la placa de estimulación del sistema con 24 voltios de CC. LA fuente de alimentación de la placa de control no me da los 24V , esta en cero, mientras que la otra si, lo cual ocasiona que mi pantalla no encienda, verifique que un transformador no funciona , dicho esto, ando en busca de esta refacción, en dado caso , tendria que comprar una fuente ¿ Alguna sugerencia o ayuda para solucionar dicho problema?Reply |
1Reply5 years ago | SEPERATE TOP AND BOTTOM The manual states to use a screw driver to separate the top and bottom shell by the ultrasound applicator rest. However this seems to not be working and putting excess strain on the plastic shell. Is there a better description on exactly where the force needs to be applied to produce the desired outcome?Reply |
- High resolution 5" (13 cm) TFT LCD vibrant color user interface
- Multiple waveform electrotherapy – 10 clinical waveforms
- Dual frequency Ultrasound at 1 MHz and 3.3 MHz†
- Pulsed or Continuous Ultrasound Duty Cycles (10%, 20%, 50% and 100%)
- Clinical Protocols
- Over 100 user-defined protocol memory positions
- Indications for quick parameter retrieval
- Impressive clinical library which includes full-color graphic anatomical and pathological libraries on vibrant LCD screen
- Documentation of treatment outcomes with Patient Data Cards
