Famed Zywiec - LE-02
by Famed Zywiec
Designed for lying of the patients in hospitals during diagnosis, monitoring and cure and for rehabilitation and resuscitation.
The construction of the bed can be made of carbon steel covered with polyester-epoxy varnish or of stainless steel. The bed has a moving system with central blockade and one directional wheel. The bed has a smooth adjustment of: pallet's height, thigh segment and back rest inclination, which are performed by means of electric actuators. Longitudinal tilts are performed manually thanks to gas spring with interlocking. The back rest is permeable for X-rays. The bed is equipped in auto-contour function. The bed pallet is equipped with 4 hooks for bags for physiological fluids. The bed enables resuscitation of the patient. As an option the bed can be made in version with: CPR function for back rest, auto-regress function in back rest and blocking panel or blocking panel with possibility of the controlling electrical functions.
-KASONGO
Fri Jan 16 2015
hospitals beds parts
do you have a correspondant of FAMED in Belgium?specially for hospital beds and their parts as wheels manner 125?
[list]       [*] A moving system with central blockade and one directional wheel.       [*] A smooth adjustment of: pallet's height, thigh segment and back rest inclination, which are performed by means of electric actuators.       [*] Longitudinal tilts are performed manually thanks to gas spring with interlocking.       [*] The back rest is permeable for X-rays.       [*] Bed is equipped in auto-contour function.       [*] The bed pallet is equipped with 4 hooks for bags for physiological fluids.       [*] Bed enables resuscitation of the patient.       [*] As an option the bed can be made in version with: CPR function for back rest, auto-regress function in back rest and blocking panel or blocking panel with possibility of the controlling electrical functions.       [/list]
Height450 to 800 mm
Bed TypeElectric
Length 2160 mm
Width965 mm
Trendelenburg/reverse Trendelenburg: 15°/5°       Back rest inclination: 70°       Thigh rest inclination: 30°       Castors diameter: 150 mm
