NDS Surgical Imaging - National Display Radiance G2
by NDS Surgical Imaging
The Radiance G2 display offers LED backlight technology to provide bright, clear images, as well as a 900:1 contrast ratio for more enhanced viewing. Designed with NDS’s patented Color Correction Technology (CCT), this display delivers the same quality of color response and consistency provided by the entire family of Radiance g2 products. Surgeons now have the clinical confidence that the endoscopic image they view in different rooms and on different size displays are exactly the same.
1ReplyThu Jan 20 2022 | NDS G2 Monitor signal input We sold a monitor to a facility a couple of thousand miles from here. The MD says that while it lights up as it should, there is no signal on the dvi or bnc connections. The G2 manual indicates: Press the INPUT button twice to open the input menu. The Input menu shows a: P for primary input in the left most column and an: S for secondary input in the column to the right of the cursor. Press the SCROLL button to highlight the desired input. Finally, press Ä button to make it the primary input or press º to make it the secondary input. The secondary input may be cleared by highlighting it using the SCROLL button and pressing the º button. Selecting a secondary input is optional. Note: Grayed out inputs are not accessible. The MD indicates that the BNC options are greyed out on the display we supplied and not on his other identical displays, The manual seems to say this means that they are not accessible. This seems a little strange to me as the model information is identical between the monitors at the site. I suspect there may be a physical dip switch setting that is creating this issue. Any suggestions? ThanksReply |
0RepliesFri Jul 13 2018 | Problems with the Software of NDS 24" I need the help with an NDS monitor that presents problems when starting, which stays in the storz logo and does not finish initiating. Q can it be? Thank you. Reply |
[list] [*] Industry-Leading LED Backlight Technology [*] Color Correction Technology (CCT) [*] Supports 3G-SDI (Resolutions up to 1080p @ 60 Hz, SMPTE 424M) [*] Low Power Consumption [*] Lightweight Design [*] 3rd Edition & RoHS Compliance [/list]
| Height | 16 in |
| Length | 4 in |
| Weight | 10 lbs |
| Width | 18 in |
Image Size: 14.8" W x 11.9" H
